Removing windshield wiper arm
Old Feb 25, 2007 | 02:20 PM
cemeteryman's Avatar
cemeteryman is an unknown quantity at this point
Default Removing windshield wiper arm
Is there a certain trick to removing the whole wiper arm? It seems the arm is stripped inside and won't operate any more. Thanks in advance, Jim
Old Feb 25, 2007 | 02:26 PM
Default RE: Removing windshield wiper arm
[:@]I've done a search (which I should have done in the first place) and probably found the solution. Sorry about taking up your time. Jim
Old Mar 3, 2007 | 10:17 AM
BrokenBlazr's Avatar
BrokenBlazr is an unknown quantity at this point
I have the same problem but I can't find the post on how to remove it......want to give me some help?
Thanks!
Old Mar 3, 2007 | 11:57 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Not sure if the 99 is like the 95's
But pretty sure they are.
but the retaining nut is under a cap.
You gently pry off the end cap and that will expose the retaining nut.
Remove the nut and off goes the arm.
Old Mar 3, 2007 | 12:12 PM
Ok....just wanted to make sure that I was not missing something. I have taken off the nut and pulled pretty hard and it did not budge and I did not want to damage anything.....so nothing else other than removing the nut?
Old Mar 3, 2007 | 12:28 PM
MNHawk's Avatar
Nope just the nut
if it is that hard to move then try using some Penitrating Oil, no WD40, but like Liquid Wrench. Let it soak in for about 2 to 3 min. Then use a LONG nose set of pliers to gently wedge them up. Careful of the plastic vent cover and the paint. Use a sponge or a thick cloth to put under the tips.
What happens with these is that they have no anti-rust protection. So they end up rotting on.
EDIT:
Just remembered a trick I had to do to a Chrysler to get them off once. I had to use a battery terminal remover (for top post mounted terminals), like a mini gear puller. It was rotted so badly it pulled the gear off the mount. Took me 10 hrs of soaking that wiper arm to get the gear out.
The tool cost is avg. $5 at most Parts Stores and Wal-Mart.
Old Mar 3, 2007 | 01:20 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
If the wiper arm still does not come off, then you need to use a puller. The puller that you may have seen for top post battery terminals, also work for the wiper arms, (Snap-On actually markets that tool as a battery terminal/wiper arm puller). It looks like a mini 2 jaw puller with a T-handle going through the forcing screw. Korey
Helter80
Jun 14, 2013 08:34 PM
richphotos
Feb 5, 2012 09:08 PM
drpcken
May 10, 2010 09:05 PM
2000BlazerSS
Dec 26, 2006 06:35 PM
tdannar
Aug 24, 2005 08:11 PM
