Replaced fuel regulator now no start
I was having hard starting problem and found the fuel pressure regulator leaking. After replacing the regulator the car wont start, it just turns over but will not start up. Does anyone have any ideas? I can hear the pump running in the tank but no start. I have a 99 blazer 4.3. Thanks for the help
should be no reason to have to bleed the line if the pump is working properly
check all the lines back to the tank if there no breaks crack the output connection on the top of the top of the tank. If on the three second prime no fuel is spitting back there you have a dead pump
is your truck on an angle these baby's are classic for zero fuel in the nose down position
My mistake, looks like I didn't prime the sysyem long enough. I do have fuel pressure at the port but still no start. I don't smell any fuel so I am guessing it is a fuel problem. I guess it could be a bad regulator
![](https://blazerforum.com/forum/attachments/2nd-generation-s-series-1995-2005-tech-41/26096-replaced-fuel-regulator-now-no-start-1pia2r.jpg?dateline=1442243378)
The fuel tube down the center of the spyder manifold came out, I found it on top of the transmission. Thanks for the help. It all doesn't matter now, seems like one of the fuel line nuts went into the manifold and now I have a blown engine. Guess I should have covered the openings more carefully. RIP
north40s
10-19-2011 05:00 PM
wallace
02-15-2011 09:45 AM
yanni011
01-07-2011 08:59 PM
95Jimmy
10-04-2009 07:21 PM
broke33
05-01-2007 10:45 PM
