Replaced Intake Manifold Gaskit, No Start
I just replaced my Intake Manifold Gaskit and had to take the whole top end apart on my 97 4.3 Vortec V6 LT. I got it back together and replaced the starter as well, new oil and cleaned off the spider injector. but it dosent want to run. When i turn it over it sounds good, i can smell fuel, and can also hear the fuel pump. Got the code reader on it and it told me that the Fuel System, Misfire, and Comprehensive Component Monitor's were all good. But i cant get it started so the comp cant run all the tests. What else should i try?
yeah i got the timing spot on. So now im thinking it might be that im not creating enough spark. . . possibly the ignition coil. I tryed to get it started so i could run a code reader, put fuel in the throtle body, and couldnt get it going. Not sure but possibly a spark problem.
One tooth off with the distributor and your blazer becomes a driveway ornament. I just had a strange problem with my ignition coil and it was fairly cheap to replace. I think the coil is ~$30 and the module is ~$70....double checking and adjusting the distributor position is free
ckrauss
Jan 5, 2013 10:58 PM
ChevyFamily
Jun 9, 2010 11:07 AM
kermit1112
20
Jan 21, 2010 11:20 AM
polecat
Mar 29, 2008 07:45 PM
greenclover19
Mar 26, 2008 03:13 PM
