Replaced Stereo...Blazer Wont Start
Old Aug 15, 2010 | 08:19 AM
A-STANK's Avatar
A-STANK is on a distinguished road
Default Replaced Stereo...Blazer Wont Start
Yesterday, i replaced the original stereo in my 98 blazer with a pioneer something or other. I got everything wired up, I went to turn the ignition and it just cranked and cranked. So, I took the new one out and replaced the old one. Still nothing. I sprayed some starting fluid in the intake and when I started it, it was catching the starting fluid but was acting like there was no fuel coming in? (And yes, there is a full tank.) Is it just coincidence something happened with the fuel lines, or should I be looking for an electrical malfunction?
Old Aug 15, 2010 | 01:54 PM
Sounds like a coincidence. I would put a fuel pressure gauge onto the test port on top of the motor. Sounds like you are experiencing a fuel pump failure. Do you hear the pump prime when you turn the key to the 'run' position?
Old Aug 15, 2010 | 01:57 PM
Red 96''s Avatar
Yeah, it shouldn't be electrical seeing as it started firing on the starting fluid. Just an unlucky coincidence in my opinion. Good luck!
Old Aug 15, 2010 | 08:01 PM
A-STANK's Avatar
UPDATE: I unhooked the fuel line forward of the fuel filter, turned the key to try and start it and pumped the gas. Nothing was coming out of the filter. I am not real mechanically inclined, but I'm assuming we're looking at a bad fuel pump?
Old Oct 13, 2010 | 11:14 PM
blazerpower's Avatar
blazerpower is on a distinguished road
could be a stopped up fuel filter or relay or bad fuel pump
welgwiz
Jan 17, 2012 01:07 AM
north40s
Oct 19, 2011 05:00 PM
reddheadnla
26
Jul 15, 2011 06:49 PM
shockley84
16
Dec 24, 2010 07:52 AM
A-STANK
Aug 15, 2010 01:52 PM
