Replacing ball joints help
Old Sep 19, 2008 | 12:26 PM
tilley101's Avatar
tilley101 is an unknown quantity at this point
Default Replacing ball joints help
I have a 97 blazer 4x4 4 door v6 vortec. I'm confused. I need to replace my front ball joints. the upper ball joints were a breeze but the lower were weird. Do the lower ball joints have to be pressed in? The new ball join i got doesnt need to be pressed but im not sure if i got the wrong part. the one i bought looks like this
"javascriptopImage('http://www.partsamerica.com/product_images/img/mcq/fa1466e-4.jpg',%20'McQuay-Norris%20FA1466E');" but i dont see how it would fit. the haynes manual says that the 2wd has to be poped in but mine is 4x4.
any opinons?
Old Sep 19, 2008 | 12:55 PM
DCFluX's Avatar
DCFluX is an unknown quantity at this point
Default RE: Replacing ball joints help
Mine just slipped in. I recall I had to give the old ones a tap with the hammer to pop them out.
Old Sep 19, 2008 | 02:04 PM
Clay_Assassin's Avatar
Clay_Assassin is an unknown quantity at this point
The part you have looks similar to my '98. I installed the moog. However, my father-in-law (GM mechanic) said he was "suprised my ball joints were bolted in, as usually they are rivited, and you have to drill the rivits out and replace the rivits with the bolts in the package"
Dont know if that helps you, but that may be the case on yours.
Old Sep 19, 2008 | 06:03 PM
AJBert's Avatar
If you had bolts in when you first changed your bj's then someone else had already changed them out.
Old Sep 19, 2008 | 08:28 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
If they are riveted in-they're original. If bolted, as stated b-4, they have been replaced. So....if yours are riveted-cut, grind, drill, air hammer or whatever but...remove the rivets-cut the heads off and punch out the remains(just did a lower within the last half hour)then as stated by an earlier poster, bolt it in, re-install all and grease(I usually do it-the new one, in my hand b-4 installing but re-grease all 3 on the side that was tore apart-upper, lower, tie rod when done). Good luck JP[>:]
Tomar1226
Dec 18, 2011 02:36 PM
Space Ace
Sep 3, 2008 11:32 AM
bitbandit
Jul 9, 2008 03:33 PM
Jorgen
Jul 24, 2007 08:40 AM
mac6135
Suspension Tech
Aug 31, 2006 06:16 PM
