Replacing the battery
Old Oct 2, 2024 | 02:59 PM
bartbartez's Avatar
bartbartez is on a distinguished road
Default Replacing the battery
Hi. I need to replace the battery with a new one. I just bought a Blazer 2001 LT 4wd and it has a small 50Ah battery in it. I know that 74Ah 680A is recommended. Will a 74Ah 720A or 750A battery also be ok?
Thank you for your help
Old Oct 2, 2024 | 10:10 PM
As long as it physically fits the batteries with the larger current rating should work.
Old Oct 3, 2024 | 02:46 PM
bartbartez's Avatar
Thank you for your reply.
I thought about a battery with a higher current because winters can be frosty where I live. I wanted to know if higher current can be used in my Blazer and it won't cause any damage.
Old Oct 3, 2024 | 03:47 PM
LesMyer's Avatar
Absolutely no fear to increase battery capacity or even case size as long as the battery hold down clamp still fits.
Old Oct 4, 2024 | 01:34 PM
puttster's Avatar
Originally Posted by LesMyer
... as long as the battery hold down clamp still fits.
...or you can avoid the big bumps in the road.
Old Oct 4, 2024 | 01:50 PM
bartbartez's Avatar
Thank you for the information
My Blazer is a bit incomplete old 50Ah battery and missing battery clamp
I will buy a new large battery and make the clamp myself.
Old Oct 4, 2024 | 02:37 PM
Here is a thread that has some information on the Optima battery I installed along with some other specs that you might find useful: https://blazerforum.com/forum/lighti...blazer-106006/
Good Luck
reway
Oct 28, 2023 10:00 PM
christine_208
Jan 20, 2021 05:10 PM
maryoka
Dec 23, 2019 08:58 AM
blazz
Dec 14, 2017 11:48 AM
SDimeBlazerlady
Dec 30, 2006 03:43 AM
