Reservoir not draining, what am I doing wrong?
Old Dec 27, 2012 | 07:53 PM
HamToast's Avatar
HamToast is on a distinguished road
Default Reservoir not draining, what am I doing wrong?
The reservoir for the radiator isn't draining when I drain the system. I can not use the plug as it is broken, so I've been using the radiator hose. I have been using the part of the lower hose connected to the radiator and am wondering if I should use the part connected to the block instead. The way I am doing it now is with the cap on, engine running and hose disconnected. The fluid stays put in the reservoir. I have also tried with the engine off and the cap off.
What should I do differently?
Old Dec 27, 2012 | 08:17 PM
warthogdriver's Avatar
what you could do and this is out there a little bit is:
connect a shop vac (in reverse )to the upper hose and use that to blow the rad out the lower hose opening...my first thought. short of pulling the rad i dont know.
Old Dec 27, 2012 | 08:37 PM
coolasice's Avatar
coolasice will become famous soon enough
are we talking radiator.. or resevoir? if its the resevoir, just remove it and dump it... if it's the radiator it's more then likely clogged and you can try flushing with a garden hose, but may not help.
DaveHearne
Dec 28, 2012 07:03 PM
mrubino
Sep 12, 2011 06:34 PM
fm5050
Mar 22, 2010 04:55 PM
vaportrail
14
Jan 11, 2010 11:12 AM
thechevytrucknut
Nov 1, 2009 11:12 AM
