rev limit
Old Jul 11, 2005 | 03:49 PM
dieselfumes's Avatar
dieselfumes is an unknown quantity at this point
Default rev limit
I have a 2000 blazer and if i try to do a burn out just by using the brake, it will only rev up to 2000 rpms. is there any way to make it rev higher or is that in the computer?
Old Jul 11, 2005 | 11:31 PM
Default RE: rev limit
no one has anything to say, also its a automatic
Old Jul 12, 2005 | 02:35 AM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Pretty sure that's the computer bro, whenever I power brake my '87 it will burn the hell out of 'em. It will shift through 1st, 2nd, 3rd, and 4th on its own.
Old Jul 12, 2005 | 04:52 AM
not mine, when i try it it will rev up to 2000, and then just take off without ever loosing traction. it sucks
Old Jul 12, 2005 | 03:23 PM
blazin97's Avatar
blazin97 is on a distinguished road
mine is like lolo's it will burn like no tomarrow, unless in 4wd then it just pushes.
chris
Old Jul 12, 2005 | 10:54 PM
damn, mine is only 2wd though
Old Jul 13, 2005 | 11:20 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
my little 2.2 in my 01 noma stick will smoke the hell out the tires. it sounds like you got traction control, but i didn't think that blazers offered that option. is there a TCS button on your dash or center console? or does a traction light come on when you do it?
Old Jul 14, 2005 | 12:27 AM
no there is not traction control on it, it just wont rev high enough to do so.
Old Jul 22, 2005 | 07:16 PM
mharrison's Avatar
mharrison is an unknown quantity at this point
Sounds to me like it's just hooking up at 2k and leaving. Not a rev-limiter problem, your brakes just aren't holding it according to this:
Old Jul 28, 2005 | 01:01 AM
c95blazer's Avatar
c95blazer is an unknown quantity at this point
i have a 95 blazer with several eng mods but the computer combind with the torque converter setup for towing wont alow it to go over 2000 rpm unless i get the tires to break los before it limits the throtal position then it will burn the hell out of them
Benedict1337
May 14, 2010 06:46 PM
bigjohns96sport
Nov 26, 2009 09:57 PM
GMdesigner
Sep 22, 2007 12:16 AM
jagblazer01
Aug 9, 2007 01:08 PM
02 Vortech
Engine & Internal
Jul 12, 2005 03:27 PM
