Right Side Horn Not Sounding - Where is the Ground
Old May 22, 2019 | 04:06 PM
Rudeness's Avatar
Rudeness is on a distinguished road
thank you for the list of things to check, it will be raining here all weekend so I will get back to you next week - this sounds like its turning into a bigger headache than I anticipated but at least it sounds like I am about to learn a lot. lol
Old May 22, 2019 | 04:23 PM
Rudeness's Avatar
Originally Posted by GeorgeLG
are you saying that the dash indicator for right turn signal turns on with horn activation but not the actual right turn signal bulb? If so, does that bulb work normally?
George
I meant the dash indicator for the right turn signal turns on with the horn activation - not sure about the the actual right turn signal bulb - however if I throw on the right turn signal - the bulb blinks but fast - the indicator also seems to click fast compared to the left turn signal
does the front right parking light operate normally otherwise? Does it go out when you attempt normal horn activation or only with the Paperclip experiment?
George
When the horn is hooked up normally, the parking light is on - not sure what happens when I activate the horn (need some help from another person to verify) The picture showing the parking light being out was with the paper clips hooked up and the car turned on idling,
Old May 22, 2019 | 08:29 PM
Rudeness's Avatar
followed positive cable from siren thru the firewall then it goes back up into side of dash with a bunch of other wires below are some pictures
Old May 22, 2019 | 11:22 PM
GeorgeLG's Avatar
The quickest way to perform a successful exorcism of that aftermarket black box is to get a model number so we can see its pin out and wiring color codes.
George
Old May 23, 2019 | 10:03 AM
Rudeness's Avatar
so you think that mystery black box is the brain box for the alarm system? or is that part of the car? it looks like it has corresponding clips that clip into the removable dash panel so it's not self evident that the box is after market. if that box is not stock i'll take some pictures and try to find a mode number. thanks
Old May 23, 2019 | 10:08 AM
GeorgeLG's Avatar
I don't recognize the black box so not sure. The extra siren and red button are not factory so I suspect an aftermarket install. Where do the wires from the red button go?
George
LuckyAce
Feb 28, 2019 10:41 PM
chris015
Sep 10, 2012 06:43 PM
jaystoy
Sep 6, 2012 09:59 PM
shmy
Oct 23, 2010 10:26 AM
victoryredblazer
Feb 25, 2005 03:06 PM
