right turn signal
Old May 30, 2012 | 07:36 PM
garyjr1992's Avatar
garyjr1992 is on a distinguished road
Default right turn signal
ok so my right turn signal and brake lights do not work. i replaced the brake light switch the turn signal switch ive replaced the bulbs and checked the fuses.. can someone please help me i dont know what else to look for. also the running lights work and the reverse lights work on the right side and the left side everything works fine its just the right side
Old May 30, 2012 | 08:37 PM
Joshua1023's Avatar
Joshua1023 is on a distinguished road
Does your right turn signal work in the front of the truck? If so, you probably have corrosion in the sockets due to water getting in the rear housing.
Old May 30, 2012 | 08:41 PM
abig84's Avatar
check for bad socket or bad ground. get a test light and check to see if it has power inside the socket if it dont, try behind the socket in the wire.
Old Jun 1, 2012 | 06:19 PM
garyjr1992's Avatar
i check the socket and theres no power going to it so that must mean there is a wire rubbing? has anyone ever had problems with this on a blazer or jimmy
Old Jun 1, 2012 | 07:56 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
do your hazards work?
Old Jun 2, 2012 | 04:06 PM
garyjr1992's Avatar
On the left they do but not the right
Old Jun 2, 2012 | 04:26 PM
scottl1346's Avatar
maybe this is messed up MULTI TURN SIGNAL SWITCH BLINKER HAZARD BUTTON REPAIR CHEVY TRUCK BLAZER SONOMA | eBay
or the whole directional assembly needs to be changed
Old Jun 3, 2012 | 02:23 PM
garyjr1992's Avatar
I already changed the whole thing
Old Jun 3, 2012 | 10:28 PM
scottl1346's Avatar
time to pull out the tester and go trough every wire
drummerdude
Dec 17, 2009 09:55 PM
ta3ff
Oct 14, 2009 05:07 PM
lionel2
Sep 19, 2009 04:14 PM
eknox327
18
Jun 29, 2009 02:38 AM
shaka1111
Feb 13, 2006 02:23 PM
