ring gear size?
Old Oct 11, 2010 | 10:48 AM
redheadstepkid79's Avatar
redheadstepkid79 is on a distinguished road
Default ring gear size?
I've got an 02 s10 blazer 2wd, I need to change out the rear wheel bearings. It seems doable but I need to be able to tell wether I have the 9 1/2 inch ring gear or not. The truck is an ls fully loaded of that helps, any ideas? Thanx.
Old Oct 11, 2010 | 11:31 AM
WolfPack's Avatar
wow 9.5"....if only...The GM 14-Bolt fullfloating, 1-ton axle had the 9.5" ring gear..the system youre looking at may be overlapping S-Series blazers and Fullsize Blazers. But even then I don't think that was the standard option for the rear axle.
Anyhow, if you have an auto transmission, youve got the 10-bolt, 7.625" ring gear, but if you have a 5-Speed, its most likely the 8.6" rear end (Also listed as an 8.5..but GM switched in '99 to the 8.6")
Old Oct 11, 2010 | 05:09 PM
step66's Avatar
I am sure the 7.5 may have been put in some Blazers (2WD espescillaly).I have never seen a 4x4 equipted with the 7.5 ring gear: All blazer/Jimmys with this axle need to be checked as the covers rust out! Check your production sheet!
Old Oct 11, 2010 | 05:52 PM
jmaynard's Avatar
jmaynard is on a distinguished road
My '95 4x4 has the 7.5 inch ring gear. Apparently, the 8.5 inch ring gear is fairly rare; I seem to recall seeing that it is present in something under a quarter of all Blazers built.
WBFAir
Feb 22, 2015 06:42 PM
csifmh
Jun 6, 2014 01:34 PM
honaberger33
Oct 18, 2010 02:06 AM
alesv
Apr 12, 2010 11:21 AM
