Rotor Hitting Dist Cap
Old Mar 3, 2013 | 10:04 AM
LannyL81's Avatar
I purchased a aluminum shaft distributor from White Machine through ebay for $50, thought I would give it a try. I have stripped out the rear cap screw threads....wonderful plastic that it is...it it working but get a cylinder 6 misfire at times due to the somewhat loose cap and the side movement in the distributor bushings.
Should have the new distributor by next weekend...well see what happens.
swanman: The distributor bolt is tight....it is the side movement of the shaft that causes the rotor to hit the cap at times.
Thanks for all the replies.
Old Mar 3, 2013 | 10:41 AM
swanman35's Avatar
swanman35 is on a distinguished road
Oh I see. Mine was coming straight up. I need a new distributor cap because the piece that you put the screw in to tighten down snapped off while putting it on somehow. It's I need of a full tune up anyway! Glad to see you got everything, good luck with it all!
Old Mar 3, 2013 | 03:32 PM
LannyL81's Avatar
Do not know what year Blazer you have, but it probably has a plastic distributor housing and that is why one of the cap mounting ears broke off. Had that happen on my '95. I ended-up putting RTV on the cap to glue it in place. Worked fine...until I would need to replace the cap....which I never did....sold it with 234k miles on it.
Old Mar 3, 2013 | 04:00 PM
Axial movement, (up and down) is normal. Radial movement, (side to side) is not acceptable.
Old Mar 4, 2013 | 05:21 PM
LannyL81's Avatar
Once I get the new aluminum housing distributor I am going to tear the plastic one apart...curious as to what it is that has worn-out that is allowing all this side play in 90k miles.
01bluerado
Sep 1, 2011 10:40 AM
r6thor
Jan 5, 2011 11:36 AM
mwillia
16
May 13, 2010 08:51 PM
scott96
May 26, 2008 09:21 PM
fnirish
Oct 24, 2006 02:02 AM
