rough idle
Old Jun 17, 2008 | 07:05 AM
gus's Avatar
gus
gus is an unknown quantity at this point
Default rough idle
Let me give the whole story. I have a code that says high RPM detected. I changed the IAC, TPS, New timing chain, Cleaned the EGR, new plugs, wires, distributor, rotor, cap, Crank position sensor and it still shows the code. It runs great except for at a stop it rough idles for 3 - 4 seconds and then is fine. During the rough idle, the oilpreasure gauge is going crazy and then it goes normal
Old Jun 17, 2008 | 07:14 AM
Default RE: rough idle
Have you verified that you have no vacuum leaks? An unlit propane torch works great for this. With the engine running, trace along all vacuum lines and the various different interfaces between components with the torch. If the idle increases or smooths out, you've found your leak.
blazerguy22
Nov 14, 2013 11:50 PM
Chevrolet.Love
Aug 19, 2011 09:05 PM
nhguy261
Dec 30, 2010 01:41 PM
97BLAZE4X4
Feb 7, 2010 07:33 PM
c10jm
Aug 12, 2008 05:34 PM
