Rough Idle when in Drive and stopped only
Old Feb 13, 2016 | 01:05 PM
  #41
LannyL81's Avatar
Never found a solution for sure yet. I think it may be the fuel injector spider as that is the only thing that makes sense to me.
jnewtonav: in your case I would check the plug wires are correct at the distributor cap. Very easy for a shop not to pay attention and get the odd side incorrect.
Old Feb 19, 2016 | 02:54 PM
  #42
jnewtonav's Avatar
jnewtonav is on a distinguished road
So you're saying the plugs could be wired incorrectly and the vehicle would operate mostly as normal except for the above mentioned issue?
Old Feb 21, 2016 | 06:34 AM
  #43
LannyL81's Avatar
jnewtonav: only making a suggestion since the trouble did not appear until after you have work done. It is an easy check, takes a few minutes to do and eliminates one possibility.
Could be that the shop did not get a plug wire all the way on or a plug is cross-threaded....could be a number of things.
I guess since you had a shop do work, take it back to them and tell them to check everything as something is not right.
Good luck.
Old Feb 21, 2016 | 09:12 AM
  #44
newguy's Avatar
check the wires at night or in a dark garage. look for arcing. Easily causes a rough idle
Old Feb 22, 2016 | 12:10 PM
  #45
puttster's Avatar
I've had this "vibration at idle in drive" for a long time. It is just enough to get the plastic door molding/window trim of the passenger side rattling. Now I have noticed that when I first put the car into gear, it jumps, which reminds me of a Ford Taurus I had with a bad motor mount a long time ago.
Another clue, but not enough to go after those mounts yet. Is there a way to see if the mount is busted without removing it?
Old Dec 24, 2019 | 02:29 PM
  #46
Chowdas CK5's Avatar
Chowdas CK5 is on a distinguished road
Lanny,
you ever figure out the problem with the rough idle? I am having the same problem on my 87K5. Thanks
Marc
Old Dec 25, 2019 | 09:54 AM
  #47
rriddle3's Avatar
Originally Posted by Chowdas CK5
Lanny,
Marc
The OP's vehicle and yours have completely different engines and this thread is 3 years old.
*THREAD CLOSED*
blazerguy22
Nov 14, 2013 11:50 PM
UnknownFish
22
Nov 14, 2011 07:40 AM
1996blazer1
Jan 24, 2010 03:36 PM
nathansr06
Nov 30, 2008 04:43 PM
bassgrinder
Mar 30, 2007 03:30 AM
