Rough Starting
Old Jul 5, 2010 | 11:56 PM
pewter00blazer's Avatar
pewter00blazer is on a distinguished road
Unhappy Rough Starting
Ok I have a 2000 Blazer 2WD and I went to Wisconsin and Indiana this weekend on the highway with no problems. Now my car is hesitating to start and now the check engine light wont go off when Im driving. Any ideas why? By the way it still has the original spark plugs and wires and cap and rotor. It has 95,000 miles on the engine now. Should I change the plugs and wires and cap n rotor or just go get the check engine light checked out?
Old Jul 6, 2010 | 12:12 AM
spdfrk_29's Avatar
spdfrk_29 is on a distinguished road
Default rough starting
I would definitely change the plugs/wires/ect since ive had all of those contribute to rugh starting in thr past in my vihicals.and getting the codes read would probobly sheed some light on ur problem if its fuel/ sensor ect related
Old Jul 6, 2010 | 01:28 AM
Thanks buddy. Yeah I rememeber when I bought the car ban new and the dealer said you dont have to change the plugs and wires until 100,000 miles I guess they were right lol.
Old Jul 6, 2010 | 09:05 AM
spdfrk_29's Avatar
I would lend u my code reader if u lived closer but few thousand miles is a little far to drive .. let me know what u come up with/turns out
Old Jul 6, 2010 | 01:11 PM
Yeah I took it to Autozone they put it on the scanner I is the mass air sensor. So I bought that and plugs and wires and cap and rotor and fuel filter. Its about time for a tuneup Might as well do everything at once to be safe.
Old Jul 6, 2010 | 06:04 PM
spdfrk_29's Avatar
Ya i would then u know it is all done and u don't have to worry about it. and the Mas sensor is very important in how the truck runs or doesnt
Old Jul 6, 2010 | 09:52 PM
ohsofly's Avatar
I betcha that mass air sensor was about 200+ bucks too... Did you try cleaning the old one with a 5 dollar can of cleaner first??? Just because the code says its a fault in the mass air circut doesnt mean that the sensor is bad... It could be dirty, have broken or shorted wires, or be leaking.
The sensor has a very thin fragile wire inside it, if that wire gets coated with grime and gum it will start giving false readings, and when the readings go out of spec they will trigger the light. I bet all you have to do is clean the sensor. They sell CRC sensorkleen and it works great.
Old Jul 7, 2010 | 09:00 PM
spdfrk_29's Avatar
I agree with you about cleaning it but i think you have to be really carefull when u do it since it is a really delicate componant and if someone has little experiance it could go wrong ie; my buddy bang it lightly and his never worked again.
RandyRhoadsFan82
Mar 29, 2014 11:22 AM
blazerguy22
Nov 14, 2013 11:50 PM
nhguy261
Dec 30, 2010 01:41 PM
c10jm
Aug 12, 2008 05:34 PM
greenclover19
Mar 26, 2008 03:13 PM
