Service Light Came On
Old Apr 30, 2018 | 07:52 PM
lathechips's Avatar
lathechips is on a distinguished road
Default Service Light Came On
2001 S 10 4wd, Orielly's scanned & codes for thermostat, brake light switch & right front wheel sensor came up. It's not over heating, brake lights work, & last month while on the rack, gave everything a good shake down. Now what? Thanks to who reply.
Old Apr 30, 2018 | 08:23 PM
Strangerock's Avatar
Strangerock is on a distinguished road
How many miles on this beast ?, did you have decent heat last winter ?....My astro throws a brake switch code every now and then (no light just in memory) I dont worry about it cause everything works also...the wheel sensor could be a chaffed wire , bad sensor or gap , dirty....its in the front hub and the wires are all visible.
Old May 1, 2018 | 02:26 PM
jacked_72's Avatar
jacked_72 is on a distinguished road
never heard of a brake light switch code, but what do I know. The thermostat code is probably a coolant temp sensor code. Wheel sensor code could be a bad sensor or your needing to resolder joints on the abs module. do you know what the actual codes are?
Mykel99
Feb 19, 2014 11:28 PM
Hollywoodsnake
Sep 12, 2010 03:34 PM
chrisblaze
Sep 15, 2009 11:05 PM
mane187
17
Dec 31, 2006 12:42 AM
minijosh
Sep 20, 2006 10:20 AM
