Should coolant hoses be getting hard and stiff?
Old Jan 5, 2025 | 11:24 AM
RedValor's Avatar
RedValor is on a distinguished road
Default Should coolant hoses be getting hard and stiff?
Does this look normal? This is a new hose I installed in 2021. The section between this hose and the thermostat housing started leaking, so I had to pull it off and investigate.
This Amazon link is what I bought, but I'm not sure how it became this "Master Pro" thing when I was expecting AC Delco. I guess maybe I shurgged it off back then and thought a hose is a hose.
Amazon Amazon
All the other hoses I replaced are AC Delco and they're just fine. Poor quality hose maybe?
I am definitely replacing this because it doesn't seal the thermostat housing anymore. I'm guessing some hoses are better made than others?
So far I am unable to separate thermostat housing from the hose.
Old Jan 5, 2025 | 12:20 PM
puttster's Avatar
That's an awfully deep clamp channel.
Old Jan 5, 2025 | 01:36 PM
That doesn't look right.
When it comes to rubber materials, there can be differences in quality.
I'd stick with AC Delco or Gates.
Old Jan 6, 2025 | 09:00 PM
Bass_Surfer's Avatar
Bass_Surfer will become famous soon enough
The hose is Chinesium crap and is mostly plasticized rubber because plastic is a lot cheaper.
The clamp groove is both from a clamp that was too tight - perhaps the wrong design and then coupled with cheap almost-rubber, it's a case of guaranteed failure.
Here's a trick for you to learn ----
If you have real hose and it's on a metal nipple - like the thermostat housing - and that nipple is ultimately grounded .... then taking a 12V test light, hook the clamp onto the B+ side of the battery and touch the tip of the tester to the clamp.
If the light even glows a bit, then the clamp is tight enough. I caveat --- if you're using poor quality hose --- this won't work.
If this works for you, then your assignment is to tell everyone WHY it lights up.
Remember --- REAL rubber hose - not silicon or wannabe-hose with plastic ingredients.
RADRaze2KX
Sep 26, 2024 12:07 PM
brettr101
Jul 10, 2018 08:18 AM
Marsden1979
Nov 2, 2015 08:26 PM
jimspahr@msn.com
Sep 8, 2013 12:50 PM
hdhogrider
Mar 22, 2010 09:15 AM
