Squeel front front driver side.
Old Nov 28, 2011 | 02:47 PM
Wisco Blazer's Avatar
Wisco Blazer will become famous soon enough
Default Squeel front front driver side.
So i have a 2000 4x4 blazer LS (4door).
Has about 97k miles on it. Truck runs and drives excellent!
BUT-----
When i reach about 50mph or above it sounds like a metal on metal squeel from my front driver-side wheel. I don't really know what to think.
Do I need...
New Wheel Bearings?
New Ball joints?
Or Something else?
Also, I just replaced all 4 shocks, but when you press on the front of the truck you get a squeak, almost sounds like rubber. I'm thinking i need to lube up the bushings.
Could these 2 sounds be related?
Thanks!
Old Nov 28, 2011 | 03:20 PM
How are the brake pads? Maybe it's just the wear indicator on the pad.
Have you inspected the clearances between the rotor & the caliper, pad, steering knuckle?
Old Nov 28, 2011 | 04:25 PM
Just took the wheel off, couldn't really tell, but i just got brand new brakes and rotors less than 5000 miles ago. It seemed like there was alot of friction though when i tried to spin the wheel. Maybe Re-Calibrating the caliper?
Old Nov 28, 2011 | 09:17 PM
After recalibrating the caliper...... It still happens, so could it be an axle bearing???
Old Nov 30, 2011 | 02:23 PM
New update, when rolling down the window and taking a hard right you can here a low grind/squealish noise. This leads me to believe its a wheel bearing, can anyone second me on this?
mamawolf70
Apr 10, 2020 10:44 AM
mcmeen0576
Mar 8, 2014 07:44 AM
20blazer13
Aug 6, 2013 02:05 PM
mr.vls
Feb 14, 2009 02:24 PM
familyman
Aug 25, 2007 04:34 PM
