starter engaging when put in gear
Old Jan 27, 2009 | 10:23 PM
chynatown's Avatar
chynatown is an unknown quantity at this point
Default starter engaging when put in gear
i got this 2000 blazer zr2 auto matic,when you put it in gear either 2nd or 3rd or sometimes just putting it in drive the starter wil engage. i also have the problem with the hazard light relay .
Old Jan 30, 2009 | 07:13 PM
ezfrank's Avatar
ezfrank is an unknown quantity at this point
Default RE: starter engaging when put in gear
I have a 96 Blazer with the same problem if i put it in overdrive you can hear the starter trying to engage as if you where trying to start it i am wondering if it is the neutral safety switch.
Old Jan 31, 2009 | 07:59 PM
ezfrank's Avatar
I was working on my Blazer tonight and found the problem i was having when i put in overdrive and my starter was engaging after tearing my dash all apart and going through all my wiring i decided let me check my neutral safety switch on the tranny i unpluged both plugs and checked them all looked good so i plug them back in and it stopped doing it it was fine again so tommorow i will by a new switch. so if anyone runs across this problem check your neutral safety switch. I am glad a came across this Blazer forum lots of great info. Thanks[sm=icon_rock.gif]
Old Feb 13, 2009 | 12:28 AM
chynatown's Avatar
changed the neutral safety switch it did the trick for almost a week and now the starter is engaging when put into 3rd again , i wondering if i should use a gm part instead of this aftermarket one?
gfritzges
Oct 1, 2021 10:52 PM
seriosbrad
Nov 7, 2015 09:08 PM
mfronczak
Nov 2, 2010 04:18 PM
ElevenevelE
Jun 18, 2010 03:11 PM
jimmy1996
May 9, 2009 09:02 PM
