gear engaging "klink"
Old May 3, 2009 | 01:00 AM
jimmy1996's Avatar
jimmy1996 is on a distinguished road
Question gear engaging "klink"
hey every one i have a 1996 jimmy and when i engage it into reverse i hear a loud klink somewhere in my rear end it only did this once when ingaging into drive but it always does it going into reverse. any help would be greatly appreciated
Old May 3, 2009 | 01:04 AM
bandidolenny's Avatar
Put the parking brake on and the tranny in neutral. Then check the u-joints on your rear drive shaft.
Old May 3, 2009 | 01:19 AM
jimmy1996's Avatar
ok thanks bro
Old May 3, 2009 | 01:57 PM
Could just be drivetrain slop. Some vehicles do it more than others. My K5 does it all the time when going into reverse. So long as you are patient and let it clink before hitting the gas pedal, it should not hurt anything.
Old May 3, 2009 | 02:47 PM
jimmy1996's Avatar
ok ya that makes sense
Old May 5, 2009 | 12:42 AM
02 jimmy's Avatar
02 jimmy is on a distinguished road
Ya I wouldn't worry to much about it, both my 01, and 02 jimmy's do the same when put in reverse, and sometimes in drive, very well could just be your u-joints.
Old May 9, 2009 | 09:02 PM
01Jimmy's Avatar
01Jimmy is an unknown quantity at this point
I had this same clunk problem, and it was the rear u-joint on the driveshaft. It was almost gone, needle bearings non existent, two of the shafts worn down to half original diameter. This was the OEM part, changed at 95K km but worn out much earlier. Funny how the dealer couldn't diagnose the problem during annual maintenance, and just said usual things about "driveline play." I guess lubing and checking U joints is not done, although it's not difficult.
I changed the U joint myself. It was a bugger getting it off the driveshaft. I tried a balljoint/U joint press, but no go. Took the driveshaft to the dealer, guy in service and he said I should be able to press it out with vise and sockets. I said I tried the balljoint press, which does the same thing. Then he put it on the shop press and got it off. Afterwards, he agreed the vise wouldn't have worked. The shop press with 20 tons did it. Didn't try melting the plastic either, don't want to be torching and banging on my driveshaft.
seriosbrad
Nov 7, 2015 09:08 PM
Pablo
Jul 13, 2011 10:53 PM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
chynatown
Feb 13, 2009 12:28 AM
