Starter Problems
My husband has changed the starter 6 times on our 97 blazer in the past two weeks. A few times the starter bolts have broken when trying to start it. This keeps happening every other day. Could anyone help with this? Also it is out of time, could that be causing the starter to mess up?
Is P1345 set in memory and the check engine light on? If so, the distributor is not aligned properly with the camshaft and will need to be repositioned. If P1345 is not set, ignition timing is not adjustable.
Starter engages but wont turn over like the battery is dead. Checked the battery its fully charged. Tried using jumper cables still does the same thing engages but wont turn over. Any idea what could cause this issue. 2004 Chevrolet s10 blazer 4.3 v6
I haven't been able to test voltage drop at the battery I do everything by myself and I have bad vision to be able to see the voltage meter sitting on the battery
Tortex53
Oct 27, 2010 11:23 AM
azaviator
Apr 8, 2010 08:04 PM
