starter won't engage
[:@] 98 Blazer 2dr , washed about 3weeks ago, since then all it does is click,click then it will
start. But this morning it went down to -36c, and was plugged in for 3 hours, and all it did
was click,click,click. I would like to know how to get the moisture out of the starter with out
removing it. thanx.
removing it. thanx.
RE: starter won't engage
i wouldnt lean towards water in starter. Check battery cables first and make sure they are tight with no corrosion in battery.
checked all connections, new battery put in. When outside temp. is not so cold it starts, but this is the first time no starter engagement.
The starter is in need of replacement. They usually get a dead spot and the only way to fix it is to replace it. HTH
[sm=smiley25.gif]The temperature this morning was only -11c, and it started no problem. Called a starter
shop and the guy said the starter is okay. The starter just needs to be taken apart and the moisture removed from it, and cleaned. He said at low temps the the contacts are frozen and when temp rises to a certain point they are not frosted anymore. The guy also said when using a pressure washer underneath the vehicle, not to directly point at the starter. So I will go that route. I will post the results when corrected.
Eagleridge5
05-29-2013 03:53 PM
lazer2000
09-16-2012 11:16 PM
burfdogg
07-03-2011 08:52 PM
