Startermotor or ign switch
Old May 18, 2012 | 08:15 PM
jim109's Avatar
jim109 is on a distinguished road
Default Startermotor or ign switch
Have a 2003 trailblazer that would,nt start no noise from starter but all other power. Shorted out solonoid with screw driver it sparked then i turned key it started right up .It worked great for a week then it did same thing
i repeated the screw driver trick & ITS WORKING AGAIN. My question is is the starter going bad or the solonoid or ignition switch .Thanks jim
Old May 18, 2012 | 10:09 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
The starter solenoid is bad, but usually if the solenoid is bad the motor isn't far from failing, which is why most places replace the whole starter
Old May 19, 2012 | 12:41 AM
Rottidog's Avatar
As far as I see it the only other issue may be the ignition switch. Check out Kyles https://blazerforum.com/forum/articl...-switch-33465/
Old May 19, 2012 | 09:53 AM
jim109's Avatar
Thanks guys . Another thing would starter relay sometimes work & then not?
Boiler_81
Oct 30, 2011 05:01 PM
01LtBlAzEr
Jul 26, 2011 10:57 AM
midnightmekanik
Feb 15, 2011 06:16 PM
GodsMechanicalCreation
Nov 6, 2009 08:18 AM
Chevy67
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Aug 28, 2009 08:23 AM
