Starts but won't keep going
Old May 24, 2020 | 11:31 AM
puttster's Avatar
Default Starts but won't keep going
Everything worked fine until I ran down the battery and tried to hurry up the jump by using an extra battery and a 6 amp recharger together. Or maybe it was when I used just the extra battery, which burned out the alligator clip while cranking and shut down power to the whole car, so much so I could not remove the key. Anyway, I reconnected the extra battery and the underhood light came back on and I could pull the key. Put the charger on and after 30 minutes the car started.
It started but couldn't keep going when I let off the gas to let it idle. Fired it up again and same thing. Battery is pretty new, just yesterday I pulled out the side terminals and replaced them with some terminal extenders. Volts now read 12.49 I put the charger on to build it up but more volts won't explain why I can't keep an idle, I don't think
Help anyone?
Old May 24, 2020 | 12:35 PM
93S10TahoeLT's Avatar
How long does it run for?
How is your fuel delivery?
And this new behavior is timed right after disastrous jump?
I hate side post same as you...
^ and I actually have those same terminal extenders but will need someone to install them . Regular ones are on for now and I had to jump a car last week. I feel I got lucky because they sure don't make it easy..
Old May 24, 2020 | 01:15 PM
puttster's Avatar
Yeah I put the extenders on and then listened to the radio with the key in ACC and forgot to take it out, which ran down the battery overnight. Maybe I shouldn't have put Vaseline on the posts.
Still, weird how now there is enough juice to start the car but not enough to keep it running.
Old May 24, 2020 | 02:00 PM
I hope you didn't fry an alternator
Old May 24, 2020 | 03:52 PM
puttster's Avatar
Alternator? I don't like the sound of that. Maybe this battery charging will help.
Last week I topped off with 5 gal of year old gas. But drove it 60 miles afterwards, no problems.... yet?.
Old May 24, 2020 | 05:12 PM
I say alternator because yeah you need a working one of those to keep the truck running past when the battery gets run down.
BT, DT.
what kind of voltage you got while it's running at the battery terminals?
Old May 24, 2020 | 05:17 PM
BT, DT.
Old May 25, 2020 | 10:04 AM
puttster's Avatar
After charging, battery was 12.66 v, Car started up, idles like regular, running batt was high, maybe14 v, I should have written it down. IDK what was the issue with idling but for now, crisis appears to be over.
19echo95
Oct 11, 2011 09:15 PM
Irish10Hockey
Dec 4, 2008 12:48 PM
FirehawkNS
Dec 20, 2007 02:00 PM
SDimeBlazerlady
Dec 30, 2006 03:43 AM
ste
Aug 8, 2006 03:19 PM
