Steering Problem 2000 Blazer 4Wd 4Dr
Old Sep 28, 2009 | 10:56 PM
3D_Illustrator's Avatar
3D_Illustrator is an unknown quantity at this point
Default Steering Problem 2000 Blazer 4Wd 4Dr
I have been having a problem with the steering when turning sharp left/right corners from a dead stop. There is a rumbling sound and the steering wheel shimmeys. The sound is similar to a flat front tire while turning. There is no belt squeel, nor is there the typical howl for a low or failing power steering pump and it is not the clicking sound of a wheel joint going bad. Once I gain speed everything seems OK.
Is this a bad power steering pump, slipping belt or ?
Old Sep 29, 2009 | 12:21 AM
Jason Rebellion's Avatar
Jason Rebellion is on a distinguished road
sounds like your rack is going out.
Old Oct 20, 2009 | 08:15 PM
I found that the grinding sound went away when the 4wd was engeged. Was advised to change the fluid in the transfer case because was sticking within the limited slip. Was told to use a synthetic oil - GM Auto-Trak ll. Two quarts solved the problem.
dharvey4651
Apr 7, 2015 04:13 PM
djsuperman
Nov 27, 2010 10:11 PM
slickvic863
Lifting Tech
36
Oct 16, 2010 08:42 PM
wardlarson
Sep 2, 2010 10:39 PM
ForkliftJeff
Sep 24, 2007 05:30 PM
