Stumbling at low RPM
Old Apr 24, 2008 | 01:44 PM
rednekk's Avatar
rednekk is an unknown quantity at this point
Default Stumbling at low RPM
My 2000 Bravada has this annoying habit of stumbling at very low speeds when the steering wheel is cut hard to either direction, like when you are pulling into/backing out of a parking space. The stumbling is getting progressively worse, and is now almost to the point of stalling completely.
Any ideas on what I should be looking at will be greatly appreciated. Thank you.
Old Apr 24, 2008 | 02:09 PM
WolfPack's Avatar
Default RE: Stumbling at low RPM
Sounds like a fuel supply issue....although I don't know what the turning would have to do with it. Mine stumbles a bit like that if I'm at a stop light and suddenly take my foot off the brake to go forward, and I'm chalking it up to a failing fuel pump as I have a few other symptoms of that sucker goin..
Old Apr 24, 2008 | 02:49 PM
rednekk's Avatar
I can't pin down the reasoning either. It'll idle all day long just fine so long as you dont turn the wheel.
Old Apr 24, 2008 | 03:01 PM
Smoked's Avatar
Smoked is an unknown quantity at this point
Could it be electrical? I know when i cut my wheel hard, or hold my electric seat button passed the point of no return you can hear my fuel pump waiver(it's loud to begin with).
Old Apr 24, 2008 | 03:27 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
That might be beacuse you are using alot of power. Like if you put the headlights on and push the window controls which should take less power than the seat the lights will dim some.
Old Apr 24, 2008 | 06:50 PM
jukdd's Avatar
jukdd is an unknown quantity at this point
is the RPM's, going up and down alot? mostly at just a stopped position?
Old Apr 25, 2008 | 09:47 AM
AJBert's Avatar
Just a guess here but it sounds to mean as though your power steering pump is straining the engine when you are at full turn. Why it would be doing that is beyond me but that's the only thing I figure out at the moment.
Old Apr 25, 2008 | 10:56 AM
garry2000blazer's Avatar
garry2000blazer is an unknown quantity at this point
It wouldn't hurt to clean the MAF and EGR.Not surehow the turning is affecting it other than the increased load from the power steering pump (which shouldn't be much until you get the to the end of the steering's travel), but these should be cleaned regularly anyway and they do contribute to the symptoms you're describing.
Streetracer94
Oct 29, 2018 09:33 AM
jester429
15
Nov 2, 2009 06:24 AM
86S10
Oct 1, 2008 11:47 AM
Blazer4U
Aug 18, 2008 07:23 PM
ChurchvilleMcBlazer
Jun 24, 2008 08:46 PM
