Suspension check. Found a few things to be a bit unusual (pics)
Im doing my brakes soon and i ordered the tie rod end for the drivers side so ima change both then do the sway bar links + upper ball joints.
About the torsion bars, I actually measured the distance from the ground to the bottom of thr wheel arch through the center of the wheel and the back side was actually approximately an inch higher than the front. Does this really indicate that the torsion bars are cranked??
PS I have kyb gas a justs not Rancho RS9000s, I believe thats matt4x4s
As he said you have to check the height from the ground to the center of the bottom part of the wheel arch and compare it with the ones in the back. However he didn't say how to figure it out based on the difference.
My front ones were 1 inch shorter in height compared to the back
Alright so I changed the drivers side outer and inner tie rods and the noise is FINALLY gone. Although im not sure whether or not the inner or outer one was responsinble since i changed both at the same time. Outer one was torn and the inner ones rubber had severe crack marks like the oned on my stabilizer link endings.
The numbness in the wheel is still there but not really a concern since its not anywhere close to being annoying like the turning sounds
Dadatone
07-26-2012 12:28 PM
travisrussell88
10-20-2011 10:16 PM
scott_wheels
01-26-2010 05:49 PM
ltown21
07-14-2007 02:24 AM
