Sway Bar End Link Install Technique?
Old Jul 15, 2013 | 07:48 PM
WalkGood's Avatar
WalkGood is on a distinguished road
Default Sway Bar End Link Install Technique?
Discovered my sway bar end links without the top nuts. They separated apart with barely any thread showing at the top. The bolts/cups must be rusty b/c I cannot even push them upward, even with a floor jack. Bought new ones on amazon.
ACDelco 46G0027A Advantage Front Sway Bar Link : Amazon.com : Automotive ACDelco 46G0027A Advantage Front Sway Bar Link : Amazon.com : Automotive
The pic shows pinkish/red bushings. The ones in the box delivered are black hard rubber. Happily surprised the parts are Made in USA. But no installation diagram or instructions. I did find a description of the parts order/orientation on this forum, no pics.
What is the procedure for installing the new links? Do you "un-load" the suspension? Or jack upwards under the control arm or under sway bar end?
How tight do you squeeze the rubber bushings? I seem to recall helping my Dad with end links on a Camaro when I was a teen. I *think* we tightened until the bushings were squeezed as wide as the metal washer/cups.
Old Jul 15, 2013 | 08:12 PM
WalkGood's Avatar
Posted by swartlkk in a CLOSED thread from 2008 ....
bolt it together as follows...
Washer on bolt, cupped end up. Bushing, tapered end up. Bolt through control arm. Bushing, tapered end down. Washer, cupped end down. Spacer. Washer, cupped end up. Bushing, tapered end up. Sway bar. Bushing, tapered end down. Washer, cupped end down. Nut.
Leave loose while assembling the other side.
Old Jul 15, 2013 | 08:44 PM
ratrodsare4ever's Avatar
ratrodsare4ever is on a distinguished road
Agreed with walkgood! I always jacked the front up and got the weight off of the suspension components. And exactly as he posted will do great. As far as how tight you go, that's exactly how I've always done it. When the bushing is the same diameter as the washer your good. Hope that helps ya man. Good luck!
Old Jul 16, 2013 | 01:54 AM
Thogert's Avatar
You are not missing the top nut. The top washer is actually a nut/ washer combo thing. It unscrews just like normal with some vice grips.
Old Jul 17, 2013 | 01:50 AM
step66's Avatar
Thats interesting as I have always swapped out my link kits with the unit on the ground!
Old Nov 19, 2015 | 07:50 PM
TMM217's Avatar
TMM217 is on a distinguished road
Anyone install the newer Moog problem solver poly end links part#k700526. Install for me was great with the barrel nut they use. Im just not sure how tight to go. Is there any torque specs on these?
Old Nov 19, 2015 | 09:21 PM
richphotos's Avatar
Should be 11ft pounds
NeMiZiS
Jun 7, 2013 12:47 PM
armstrong001
Mar 19, 2013 08:27 AM
RyanBiggs
Apr 26, 2012 02:17 PM
Yooper
Nov 6, 2009 07:26 PM
Bad Ramer Jamer
Sep 12, 2008 06:55 AM
