Temp guage stopped working
So after I fussed with the 2-4wd vacuum control and hoses, now my temp guage indicates nothing. I assume I knocked off a connector or broke a wire.
Where is the sending unit and what did I most likely do.
I was under the battery support shelf, I was tugging the vacuum hose that runs from that actuator under the shelf and following it up across the engine to behind the distributor on the firewall.
Suggest a place to look for a loose wire I bumped in those areas.
Thanks.
Thanks.
slide72
01-15-2014 01:47 AM
Schills
09-16-2010 09:15 AM
bertrenolds
12-19-2008 07:45 PM
myronhntr80
03-06-2008 07:58 PM
