testing front differential
Old Oct 25, 2008 | 08:54 AM
catdogs's Avatar
catdogs is an unknown quantity at this point
Default RE: testing front differential
Thanks - I've tried search, nothing yet. I'll keep searching. How does that collar/pin system work?
Old Oct 25, 2008 | 01:08 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
what I would do next is follow the fr diff cable down to where it attaches to the fr diff. See it? It should be held in place with I believe 5-15mm bolts. Take them out, this is what I believe someone else is taking about. With these bolts removed, remove the plastic collar- SHOULDN'T just pull off and out of the way. Should be clipped to the fr diff shaft-you haven't seen yet. You may have a struggle getting it off but keep rotating it, pulling on it and it'll come off. This is step 1 verifying the fr diff cable is indeed hooked up. If it is or isn't get this cable housing off to the side and you'll see a shiny metal 'actuator', for lack of a better word. Hopefully the vehicle is(or can be) jacked up. If not, do it now. Pull this actuator out about quarter or half an inch-if vehicle IS in 2wd(verified by slip shaft free), pulling this shaft should pull the front of this system in(lock slip shaft in or reach over and rotate a front tire by hand-should lock the slip shaft in[:-]-if it does....great-because your issue IS NOT in the front differential. The bad news is you missed something along the way-but....we'll help you so not all is bad! good luck JP-PS that's my 2 cents worth and today it's on sale for free! To condense...if the cable was unhooked I would do all the above anyway cause you're in this deep already-but if the cable were unhooked-that most likely is your problem but I would double check the operation of the front diff anyhow.[:'(]
Drew4711
Oct 6, 2012 12:47 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
fjdavid
Aug 16, 2007 07:32 AM
kerander
Apr 26, 2007 01:45 PM
dax44
Dec 26, 2006 08:39 PM
