third stop light removal
I don't know if yours is the same as mine, but if it is mounted to the roof of the truck, I think all you have to do is remove the screws holding it down. You will have some holes in the roof you may need to seal up to keep water from getting into the vehicle. To get to the electrical connection, you may need to remove the rear upper trim panel inside...
Here's a diagram:
Here's a diagram:
If you cannot remove the light with the screws out, it is mostlikely due to the gasket holding the light on. I would try to gently pry the light up with something flexible and non-marring between the gasket and the body of the truck (so you don't scratch it). The only thing that retains the light to the body is the screws. From there, it's just the light, the gasket, and the body... Nothing mechanical holding it.
[sm=exactly.gif] I just removed 3 of them tonight off of different vehicles (long story).
Remove the screws and grab it and twist/tilt it until it comes off. Use some muscle! If that doesn't work, try the non-marring prying technique suggested above.
The only things holding the light to the truck are 2 screws and a gasket.
Man-up on it a bit!
*Combining consecutive posts*
[sm=youreright.gif] (Rooster...LOVE yer avatar!!)
Dealer quoted me $125 for this POS today....uninstalled....part only!!!!!!!!!!!!!!!!!!!!!!!
[size=1]*EDIT by swartlkk* - Combined consecutive posts. Please use the edit function to add additional information if another member has yet to reply[/url]
Man-up on it a bit!
dannyb91979
Jul 16, 2013 06:08 PM
step66
Jan 12, 2013 10:51 AM
Lynnwoodspecial
Sep 15, 2010 09:20 PM
PAGuy77
Jan 17, 2007 10:40 AM
