throttle blade sticking?
i sprayed carb cleaner in there trying to clean it off did nothing. its almost like there a kink in the throttle cable. the pedal and all got stuck down. i had my mechanic look at it and he said he's never seen such a thing. he's thinking its one of the cables or the pivot point in the pedal
lube the gas pedal with something other than WD-40. WD-40 is NOT a lubricant. it is a Water Displacer, hence WD. use something like a penetrating oil or a power lube. you will be much better off.
ComputerNerdBD
10-03-2022 01:34 AM
96chevblazer
Performance & Brainstorming
15
10-07-2009 09:01 AM
azembdriver
07-19-2009 03:12 PM
