throttle blade sticking?
Old Feb 22, 2013 | 10:36 AM
Twip's Avatar
Originally Posted by FOGEL
i sprayed carb cleaner in there trying to clean it off did nothing. its almost like there a kink in the throttle cable. the pedal and all got stuck down. i had my mechanic look at it and he said he's never seen such a thing. he's thinking its one of the cables or the pivot point in the pedal
spray some throttle body cleaner on a rag and, with two fingers, you can get in there and scrub the junk off. make sure that you get the back side. check to see if you have an idle hole in the the throttle blade and make sure that it is clear if you do.
lube the gas pedal with something other than WD-40. WD-40 is NOT a lubricant. it is a Water Displacer, hence WD. use something like a penetrating oil or a power lube. you will be much better off.
ComputerNerdBD
Oct 3, 2022 01:34 AM
slcblazer
Headers, Intake, & Exhaust
54
Feb 28, 2017 06:58 PM
bigkeith11
Dec 17, 2011 06:28 PM
96chevblazer
Performance & Brainstorming
15
Oct 7, 2009 09:01 AM
azembdriver
Jul 19, 2009 03:12 PM
