Throttle Body questions
Old Apr 30, 2010 | 07:20 AM
swizznuker's Avatar
swizznuker is on a distinguished road
Lightbulb Throttle Body questions
Hey all:
After removing the throttle body, how do you clean it? just spray it with cleaner like you would the Mass Airflow Sensor, except use TB cleaner?
And there was a trick somewhere online that now I can't find that said that by removing something from the throttle body, (not changing out the blade, but that would work great too) it would be a performance upgrade.
I wonder if anyone knows what the hell I am talking about
Old Apr 30, 2010 | 07:31 AM
You can use an old tooth brush to clean the hard to get to areas. You should also remove the IAC valve and clean it and its bore. It is the metal cylinder held in by two torx screws.
As far as throttle body modification goes, search on here for "deflector" and read up on it (you can further constrain you search using the advanced search and putting in my username as the author). It isn't a performance boost and has associated issues with the removal. I completely removed it and wished I hadn't.
Old Apr 30, 2010 | 07:49 AM
swizznuker's Avatar
Wow thanks for the info... I won't be messing with that then
Old Jul 15, 2010 | 08:10 PM
chevy ll man's Avatar
chevy ll man is on a distinguished road
that plate is there to ease drivablity and smooth throttle response i think you would be unhapy with it lunging at stop lights dont mess with it just clean it
orb1788
Performance & Brainstorming
Apr 30, 2010 09:26 AM
shawn_dh
Engine & Internal
Jun 13, 2005 04:16 PM
blazernewbie
Apr 17, 2005 09:55 PM
02 Vortech
Engine & Internal
Mar 13, 2005 11:20 PM
94Blaze
Engine & Internal
Jan 5, 2005 09:59 PM
