timing belt/chain
Old Jan 25, 2011 | 05:18 PM
avfrff's Avatar
avfrff is an unknown quantity at this point
Default timing belt/chain
I need some opinions. I have my 2003 Blazer 4x4 with about 86k on it, in the shop to replace the water pump and intake manifold gasket since they were causing my coolant leak. My question is: would be cost beneficial to have them go ahead and replace the timing chain/belt? This was my dad suggestion and not the shops. Thanks in advance for advice
Old Jan 25, 2011 | 05:59 PM
step66's Avatar
If you want to remove the timing cover,a good time to do it! As most will be apart anyway! Good timing! pun intended!... Have fun! step66
Old Jan 25, 2011 | 06:21 PM
rriddle3's Avatar
These engines have a chain, not a belt, and very rarely need replacing unless it has stretched over a lot of miles. It's your call.
Old Jan 25, 2011 | 07:44 PM
It likely is still in perfect working order.
drblaze
18
Jun 22, 2011 01:58 PM
Blazer Guy
Apr 5, 2011 08:29 PM
woodsballr
Feb 20, 2007 12:25 AM
aris_unlimited
Engine & Internal
Dec 15, 2006 12:19 PM
2001blazer
Nov 10, 2006 12:48 AM
