Too much air coming in to throttle body
Old Jul 22, 2012 | 10:20 AM
blazzer1's Avatar
blazzer1 is on a distinguished road
Default Too much air coming in to throttle body
  • I have a 2001 Blazer 4x4 LT and just replaced the fuel pump about 3 weeks ago. Now, when you hit the gas it falls flat on it's face. With pedal to the floor, I'm going about 10-mph. Just replaced the plugs and wires and the vacuum lines, no change. Carborater on top of the manifold sounds like a jet engine. Too much vacuum. Idles fine, but when I try to apply any fuel it flattens out. Again, it starts up perfectly and idles fine, only when I push the accelerator, it falls on it's face. Any help would be greatly appreciated. Thanks!!!
Old Jul 22, 2012 | 12:23 PM
50lb_cat's Avatar
Try unplugging the MAF sensor to see if it helps. If it does then clean it with MAF spray cleaner.
Old Jul 22, 2012 | 12:57 PM
Is the SES light on? If so ,what DTC's are in memory? Have you checked fuel pressure and leakdown? Have you checked for excessive exhaust back pressure, (possible restriction in catalytic converter)?
Old Jul 22, 2012 | 06:11 PM
blazzer1's Avatar
thanks but that did not help though it's clean now.
where would i find that LT? i don't have an analyzer. I suppose i need one.
Last edited by swartlkk; Jul 22, 2012 at 06:21 PM. Reason: *COMBINING CONSECUTIVE POSTS* Please use the edit function to add additional information to your post if another member has yet to reply. Rules are Rules.
Old Jul 22, 2012 | 06:57 PM
blazer_grl's Avatar
blazer_grl is on a distinguished road
Sounds like the engine is suffocating. Perhaps it is a restricted air filter? Or a hose may be collapsing on itself when the throttle is pressed?
Tenagator
Jan 22, 2014 06:04 PM
tmoble
Jun 29, 2011 11:04 PM
PHATSPEED7x
Sep 18, 2009 06:06 AM
94camaro
Performance & Brainstorming
Dec 15, 2008 02:15 PM
Parkonahill
Oct 20, 2008 05:33 PM
