transfer case shift motor
The front driveshaft can make this a pain, but here is the procedure:
Removal Procedure [ol][*]Remove the transfer case shield. Refer to Shield Replacement.[*]Remove the transfer case wiring harness connectors from the motor/encoder.[*]Remove the bolts that secure the motor/encoder to the transfer case.[/ol]
The transfer case encoder motor is located on the driver side front portion of the transfer case.
Heya.. It was pretty simple to unbolt the T-Case motor from the T-case, you mentioned that the drive shaft would make it difficult. Does that mean you have to remove the drive shaft? I said there fiddling with the T-case motor trying to get it to wedge out some way or another and it just wouldn't fit.
I also had a couple other questions about the brake switch.
Flyfishen
Jun 18, 2019 11:22 AM
PsychoGMRS
Apr 10, 2019 07:08 PM
ChrisNick78
Nov 25, 2012 08:09 PM
live4liftin
Sep 12, 2010 09:39 PM
doodad69
Nov 29, 2008 03:25 PM
