transfer case shift motor
Old Apr 6, 2008 | 09:59 AM
walkingtall's Avatar
Banned
walkingtall is an unknown quantity at this point
Default transfer case shift motor
hello I have a 98 chevy blazer and want to replace the transfer case shift motor can anyone tell me how this is done, and if it is hard to do. thanks
Old Apr 6, 2008 | 04:37 PM
Default RE: transfer case shift motor
The front driveshaft can make this a pain, but here is the procedure:
Removal Procedure [ol][*]Remove the transfer case shield. Refer to Shield Replacement.[*]Remove the transfer case wiring harness connectors from the motor/encoder.[*]Remove the bolts that secure the motor/encoder to the transfer case.[/ol]
The transfer case encoder motor is located on the driver side front portion of the transfer case.
Old Apr 7, 2008 | 09:25 AM
Banned
thanks for the info, now do you have to move the drive shaft and if so what is involved in doing that.
Old May 26, 2008 | 07:12 PM
Swiss's Avatar
Swiss is an unknown quantity at this point
Heya.. It was pretty simple to unbolt the T-Case motor from the T-case, you mentioned that the drive shaft would make it difficult. Does that mean you have to remove the drive shaft? I said there fiddling with the T-case motor trying to get it to wedge out some way or another and it just wouldn't fit.
I also had a couple other questions about the brake switch.
Flyfishen
Jun 18, 2019 11:22 AM
PsychoGMRS
Apr 10, 2019 07:08 PM
ChrisNick78
Nov 25, 2012 08:09 PM
live4liftin
Sep 12, 2010 09:39 PM
doodad69
Nov 29, 2008 03:25 PM
