transmission cooler line repair
Old Aug 20, 2022 | 06:09 PM
int3414's Avatar
int3414 is on a distinguished road
Default transmission cooler line repair
has anyone ever cut out a section and used rubber gas line to repair with hose clamps?...if so what size line...thanks!
Old Aug 21, 2022 | 09:48 PM
I wouldn't recommend it. If you MUST do that, at least use transmission cooler hose instead of fuel line hose. And use at least two clamps at each end to help keep it from slipping off the metal line. Better yet, use a flaring tool on the metal line to make a "bump" so the hose can't slide off. Personally, if I had to cut out a section, I would replace it with the same size metal line and use good quality compression fittings to join it.
As for size, I think the metal lines are 3/8", but I've never measured. They may be metric.
Old Aug 22, 2022 | 03:27 AM
int3414's Avatar
thanks,,,won't be long,whole car to the junk yard
Impact
Mar 30, 2015 08:31 AM
hypedave
Sep 1, 2014 08:06 PM
mitchell27
Jan 30, 2013 12:16 PM
tmar04
Apr 8, 2011 04:29 PM
stevelknievel
Apr 29, 2007 05:34 PM
