Transmission Pan obstructed
Old Aug 13, 2009 | 01:24 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Originally Posted by aaron.b
I'm going to attempt a pan drop on my 97 Bravada this weekend. Hope I can get the pan out without messing with the crossmember or lifting the transmission but will do what it takes to get the job done and I also plan on adding a B&M drain plug for future changes. Couple questions in case I do need to detach the tranny from the crossmember....
1. Where are the two bolts that need to be removed located? Are these the two bolts directly beneath the crossmember?
2. When lifting the transmission an inch or two can I use a regular car jack or do I need a special transmission jack? And where under the transmission can it be lifted?
yes + yes! hope it helps!
i put the jack just behind the xmember.
Old Aug 13, 2009 | 02:10 PM
aaron.b's Avatar
aaron.b is on a distinguished road
thanks Ugly Monkey! Were you saying yes to using a regular jack or to using a special transmission jack?
Old Aug 13, 2009 | 05:28 PM
any old jack, you could just wedge a board in if u wanted or have a body building midget hold it. its very unlikely your going to damage anything as long as your carefull. just remember to unbolt it from the xmember first, lol!
Old Aug 13, 2009 | 06:21 PM
nineteensixtycaddy's Avatar
nineteensixtycaddy is on a distinguished road
Default Hmm... brings up a question.
while werkin on this here 95 blazer 4x4 automatic w/ push button 4wd, I finally got the engine out. However, in pulling and pushing at it, and havin the trans on a stand (just incase), I noticed my trans started leaking from being supported by a jack and 2x6's. It's now leaked about 2 quarts and from what I can see it's coming from the pan gasket. Should I try to tighten the pan bolts when I'm done with this engine r+r, or just replace the gasket?
Thanks
Chris
Old Aug 13, 2009 | 07:18 PM
Thanks
Chris
I would replace the gasket! but its proly actually leaking from the seal at the tcase.
In the future you should start your own thread to ask such questions that dont really have anything to do with the OP!
Campesino
Dec 31, 2008 02:01 PM
salvy
Nov 3, 2008 03:51 PM
countryguy1713
Feb 27, 2008 01:54 PM
dmndeacon
Jan 20, 2007 12:46 PM
cherryred4x4
Jun 22, 2006 10:52 PM
