Truck won't start
Old Sep 21, 2019 | 05:13 PM
Bepjer28's Avatar
Bepjer28 is on a distinguished road
Default Truck won't start
I have an 03 4 door ls 4wd... The other day I was driving it with no problems. I stopped at the last store and when i was done the truck wouldn't start. It would crank but not turn over. I poured gas in the throttle body and it started right up but died once that fuel was burned off. I can hear the fuel pump working and the injectors are working. I changed the fuel filter and now it will turn over but sputters and dies. I try hitting the gas pedal to keep it running but it still dies. Any help would be appriciated... I don't know what to check next.
Old Sep 22, 2019 | 03:20 AM
GeorgeLG's Avatar
Next step is to perform the complete fuel pressure tests in the sticky at the top of this forum.
George
Old Sep 28, 2019 | 01:11 PM
Bepjer28's Avatar
I replaced the fuel filter and now it starts but immediately sputters and dies... If I give it has it dies and back fires... It was coding p0118 and the ECT sensor was unplugged... I plugged it back in and no longer codes but still does the same thing.
Old Sep 28, 2019 | 01:44 PM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
check fuel pump actual pressure....
Old Sep 28, 2019 | 02:26 PM
Bepjer28's Avatar
The pressure is low... The fuel pump works... New fuel filter... There is a gurgling noise from the back of the engine every time I turn the key off. What else could be causing the low pressure?
Old Sep 29, 2019 | 09:23 AM
Bepjer28's Avatar
An update... The truck is running now... I ended up replacing the fuel pump... I'm not sure what was wrong with it as it was pumping fuel at a good rate... But just an fyi if you remove the gas tank empty it before you put it back in.
Old Sep 29, 2019 | 07:30 PM
LesMyer's Avatar
Glad to hear you was successful. Good job!
Philip Mildren
Apr 30, 2017 04:53 PM
jaz68
Nov 26, 2014 09:05 AM
1997liftedblazer
22
May 22, 2009 08:40 AM
millertimee
Mar 24, 2008 01:32 PM
AdamM
Oct 17, 2007 04:33 PM
