Turn signal relay
Old Apr 10, 2010 | 11:20 PM
jfiord's Avatar
jfiord is on a distinguished road
Default Turn signal relay
Hi,I have a 2000 Blazer,i can hear my turn signal relay on all the time making the blinking noise except when i apply the break it goes off the turn sigs work but the blinker noise is driving me crazy,i replaced the relay today now when i turn the key its a buzzing sound,do i need to replace the whole turn signal unit odoes someone have a fix? Until then music is turned up..... OK the correct name is the thermal flasher is what im hearing? not relay
Old Apr 13, 2010 | 12:00 AM
RQuickDraw's Avatar
RQuickDraw is on a distinguished road
I had the same problem with my 2000 Jimmy about a year ago. I replaced the multi-function switch on the column and that solved the problem. Hope this helps.
Old Apr 13, 2010 | 01:03 AM
HcHawks09's Avatar
maybe try an ELECTRIC flasher instead of a thermal one, I honestly dont know if that will help or not, but worth a shot for $10
Old Apr 13, 2010 | 06:28 PM
jfiord's Avatar
Thanks for the info,but I fixed the problem using this and saved 300.00 on a new part.
http://www.automotiveforums.com/vbul...d.php?t=577320
P.S.if anyone ever has this problem with your multifunction switch,try the above first,it really worked for me and can save you $$$$ When I took mine apart I first sprayed it with CRC electronic cleaner i mean soak it good to get all the old grease and dirt out then clean it with q-tips...fixed
Last edited by swartlkk; Apr 14, 2010 at 01:32 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to include additional information in your post if another member has not yet replied.
SubbinBlazer
May 24, 2013 12:56 PM
ta3ff
Oct 14, 2009 05:07 PM
bestes
May 31, 2008 03:16 PM
VW Petrolero
Jun 18, 2007 06:40 PM
shaka1111
Feb 13, 2006 02:23 PM
