URGENT!!!!! Will not shift into PARK
Old May 24, 2009 | 06:11 PM
Hiddenfarce's Avatar
Hiddenfarce is an unknown quantity at this point
Default URGENT!!!!! Will not shift into PARK
The shifter suddenly will not return to the PARK position. I can move freely through R-N-OD-D-2-1, but the shifter will not return to the P position.
Does anyone have any suggestions?
1998 ZR2 Blazer 2dr 4wd
Old May 24, 2009 | 06:16 PM
TripleBlackBlazer's Avatar
Saw in another post that you're body lifted. Have you checked the linkage underneath for any obstructions?
Old May 24, 2009 | 06:42 PM
doing that now. I'll update in a little while.
Old May 24, 2009 | 07:07 PM
carterx's Avatar
carterx is on a distinguished road
Never heard of that happening before. Eager to find out the fix.
Old May 24, 2009 | 08:18 PM
There seems to be no obstructions on the linkage from the tranny to where it goes into the floor board.
Old May 24, 2009 | 08:19 PM
no body lift or suspension lift. mostly stock ZR2
Old May 24, 2009 | 08:50 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Pop the tranny linkage at the trans, and hand shift through each one counting. if there all there and you put it in park that way then your cable is fouled or something. there is a pin inside the trans that can come loose too, not sure how likely it is but ive seen it happen. since you have no park you are of course going to want to block your wheels.
hope it helps!
Old May 24, 2009 | 08:55 PM
Thanks I'll try it. I read another posting with some helpful info right here http://en.allexperts.com/q/Steering-...shift-park.htm
Old May 25, 2009 | 11:15 AM
I found the problem. The linkage on the tranny was fine and dandy. There is a shift actuator on the column that tells the computer what gear the tranny is in producing the lighted indicator on the console. This actuator also prevents you from shifting into drive without pressing the brake. Well, The detent socket on mine got brittle and broke detaching it from the column. The actuator still works in the rest of the gears except PARK because the notch on the rod that goes through it pushed the whole actuator instead of just clicking the switch inside the actuator allowing the shifter to go into P.
Last edited by Hiddenfarce; May 25, 2009 at 11:33 AM. Reason: That itch you can't scratch
Old May 25, 2009 | 11:21 AM
Sisk's Avatar
hmm interesting problem/solution. Thanks for the update!
derekhollister
Jun 5, 2017 10:55 PM
myhotrod1968
Jul 31, 2011 09:21 PM
ffalan
Aug 1, 2010 10:49 AM
toolman243
Jun 4, 2010 05:29 PM
Chakoose
Mar 27, 2009 04:35 PM
