Vacuum Line?
Old Aug 4, 2016 | 04:10 PM
UpInSm0kE's Avatar
UpInSm0kE is on a distinguished road
Default Vacuum Line?
Hello all,
First off, I know that vacuum problems have been beat but I can simply not find a diagram that shows every vacuum line under the hood and where it connects.
I recently purchased a 2001 Blazer ZR2 with 114000 miles on the clock. I just finished up a Transfer case input shaft seal and intake manifold gasket replacement. While I had the motor apart for the intake I took the liberty of attempting to blow out the ATF fluid out of the vacuum lines. The problem is I have a vacuum mystery hose that is running down to the secondary air pump that I have no clue where the other end is supposed to go. It blew off of somewhere when I was blowing out the lines with low pressure. Can someone please help with a detailed vacuum diagram from a FSM or tell me where this thing goes? Thanks in Advance.
<a href='https://postimg.org/image/7ukpte1i7/' target='_blank'><img src='https://s19.postimg.org/7ukpte1i7/WP_20160804_003.jpg' border='0' alt="WP_20160804_003"/></a><br/><br/>
<a href='https://postimg.org/image/t5i9xnjmn/' target='_blank'><img src='https://s19.postimg.org/t5i9xnjmn/WP_20160804_004.jpg' border='0' alt="WP_20160804_004"/></a><br/><br/>
<a href='https://postimg.org/image/bgqj617vj/' target='_blank'><img src='https://s19.postimg.org/bgqj617vj/WP_20160804_005.jpg' border='0' alt="WP_20160804_005"/></a><br/><br/>
<a href='https://postimg.org/image/s5rz1y4gv/' target='_blank'><img src='https://s19.postimg.org/s5rz1y4gv/WP_20160804_006.jpg' border='0' alt="WP_20160804_006"/></a><br/><br/>
<br /><a target='_blank' href='https://postimage.org/'>images upload</a><br /><br />
Attached Thumbnails Vacuum Line?-wp_20160804_003.jpg   Vacuum Line?-wp_20160804_004.jpg   Vacuum Line?-wp_20160804_005.jpg   Vacuum Line?-wp_20160804_006.jpg
Old Aug 5, 2016 | 02:41 PM
LesMyer's Avatar
Big Port on the end of the line goes to the PCV fitting on he manifold, as a source of vacuum. Smaller port supplies vacuum to the HVAC feed in the last photo
Attached Thumbnails Vacuum Line?-pc_20160805_151033_zpszzvcsoti.jpg   Vacuum Line?-pc_20160805_150753_zpstgsoxndi.jpg   Vacuum Line?-pc_20160805_151005_zpspzcs4nm2.jpg
Old Aug 8, 2016 | 11:25 AM
UpInSm0kE's Avatar
Thankyou! That was the correct routing and it resolved my vacuum leak issues.
Old Aug 9, 2016 | 07:27 AM
LesMyer's Avatar
You are welcome
bruce_w
Oct 27, 2024 04:16 PM
Bberry20
Oct 27, 2009 02:44 PM
tesshin
Apr 28, 2007 03:12 PM
dusted800
Nov 17, 2006 06:32 PM
1996BZR
Jun 2, 2006 08:56 PM
