Vacuum Line?
Hello all,
First off, I know that vacuum problems have been beat
but I can simply not find a diagram that shows every vacuum line under the hood and where it connects.
I recently purchased a 2001 Blazer ZR2 with 114000 miles on the clock. I just finished up a Transfer case input shaft seal and intake manifold gasket replacement. While I had the motor apart for the intake I took the liberty of attempting to blow out the ATF fluid out of the vacuum lines. The problem is I have a vacuum mystery hose that is running down to the secondary air pump that I have no clue where the other end is supposed to go. It blew off of somewhere when I was blowing out the lines with low pressure. Can someone please help with a detailed vacuum diagram from a FSM or tell me where this thing goes? Thanks in Advance.
<a href='https://postimg.org/image/7ukpte1i7/' target='_blank'><img src='https://s19.postimg.org/7ukpte1i7/WP_20160804_003.jpg' border='0' alt="WP_20160804_003"/></a><br/><br/>
<a href='https://postimg.org/image/t5i9xnjmn/' target='_blank'><img src='https://s19.postimg.org/t5i9xnjmn/WP_20160804_004.jpg' border='0' alt="WP_20160804_004"/></a><br/><br/>
<a href='https://postimg.org/image/bgqj617vj/' target='_blank'><img src='https://s19.postimg.org/bgqj617vj/WP_20160804_005.jpg' border='0' alt="WP_20160804_005"/></a><br/><br/>
<a href='https://postimg.org/image/s5rz1y4gv/' target='_blank'><img src='https://s19.postimg.org/s5rz1y4gv/WP_20160804_006.jpg' border='0' alt="WP_20160804_006"/></a><br/><br/>
<br /><a target='_blank' href='https://postimage.org/'>images upload</a><br /><br />
Big Port on the end of the line goes to the PCV fitting on he manifold, as a source of vacuum. Smaller port supplies vacuum to the HVAC feed in the last photo
