Vibration problem in passenger side front end'
Old May 20, 2010 | 04:58 PM
seashore's Avatar
seashore is on a distinguished road
Default Vibration problem in passenger side front end'
Hello everyone,
What I am having a issue with is when driving along everything is fine even on the freeways. but sometimes when I hit a pot hole/bump I will get a bad sound from the passenger side front end. The best way to describe the noise is this, its sounds like when you are on the freeway and they have the warning grooves on the side of the road and you go over them. Sometimes when you hit another bump shortly after it starts the noise will go away. If it does not I have to slow way down to make it go away. Ball joints were replaced (3 days ago) after being told that was most likely the cause and so was the tie rod a year ago when this started and they thought that was the cause. Any ideas where to go from here?
Bob
2000 Blazer LS 4WD
Old May 20, 2010 | 10:03 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
wheel bearing is shifting vehicle weight from one side to another when youy hit a bump. bad wheel bearing.
Old May 20, 2010 | 11:09 PM
seashore's Avatar
Thank you that is what someone locally here told me also, so I think that is where I am gonna look next.
Old May 21, 2010 | 10:09 AM
jck1961's Avatar
jck1961 is an unknown quantity at this point
Another possibility could be a stuck transfer case vacuum switch thats allowing vacuum to the front differential continuously. When this happened on mine it would intermittently sound like the right front tire was running on rumble strips until you slowed down to 10 - 15 mph or pushed the 4wd button.
Old May 24, 2010 | 01:28 PM
seashore's Avatar
wheel bearing is shifting vehicle weight from one side to another when you hit a bump. bad wheel bearing.
Will i hear the grinding noise more if I put the vehicle into 4HI or 4LO?
I ask because when I put the vehicle into 4Hi and LO i can hear a bit of grinding noise but in 2 wheel drive it goes away until i hit a bump.
Old May 24, 2010 | 05:00 PM
when you nput it in 4 wheel drive, the cv shafts are turnicg the wheel bearings, basicly forcing the wheels to move, when its in 2 wheel, the front wheels are getting pushed so their is less pressure on the bearings, so yes 4 wheel drive could cause a louder wheel bearing noise. try this, take a couple of hard left turns and a couple of hard right turns and which ever way you turn makes the most noise, replace the other side wheel bearing. for example if the noise gets louder when you turn left, the problem is the right wheel bearing.
Bigjoe1986
22
Dec 2, 2015 04:29 PM
TheDevilsDaddy
Oct 12, 2015 10:34 AM
lionel2
Sep 29, 2012 03:52 PM
upmaine
Jul 9, 2012 12:31 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
