water sounds from behind dash
Old Jan 18, 2007 | 02:32 PM
bklahl's Avatar
bklahl is an unknown quantity at this point
Default water sounds from behind dash
I havea 1997 Blazer 4X4. I have a couple of problems but maybe they are related. When driving around I hear sloshing noise coming from behind the dash board. Its like there is a stream back there. I also have a problem with the amount of heat coming out. When you put on the heat it will blow out heat, not very hot and not very much pressure. IfI move the temperature from hot to cold the pressure picks up dramatically. Does anyone have any suggestions on either of these problems.
Old Jan 18, 2007 | 02:34 PM
alamantia's Avatar
alamantia is an unknown quantity at this point
Default RE: water sounds from behind dash
clogged heater core... orrrrrr... in one Monte carlo SS i had a bunch of leaves got caught in the venting behind teh blower motor trapping rain water, i suggest you remove the blower motor and stick your hand in the hole and see if there are wet leaves and water puddeling back ther, if not that pull the hoses off yoru heater core and flush it out with a garden hose. thats what I would do
Old Jan 18, 2007 | 02:40 PM
I'd say the same about the core. Flushing is quite easy. Run a search and you'll find the answers you seek.
Old Jan 18, 2007 | 04:40 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Yea my blazer too seems like it has a stream of water behind the dash only thing is that I get a good amount of heat and cool air.
Old Jan 18, 2007 | 09:44 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
I'll third that about the water sound. It seems like it's only on acceleration from a stop though. My heat is 'f'ed but the pressure is just fine, I have another post about the heat. https://blazerforum.com/m_59570/tm.htm
Old Jan 20, 2007 | 11:39 PM
tim03parts's Avatar
tim03parts is an unknown quantity at this point
William,
Does it sound like a gurgling noise? Mine had a similar sound and it turned out to be just a bad radiator cap. Try that first and see before you make any expensive repairs.
Tim
ABSLT
Dec 7, 2011 02:03 PM
wood0470
Mar 31, 2011 11:29 AM
napalm dan
Apr 17, 2007 12:53 AM
huskers95
Oct 7, 2006 02:39 AM
camohog1
Jan 24, 2006 07:46 PM
