weird headlight and lock problem
Old Apr 1, 2010 | 03:24 PM
twiztedI8's Avatar
twiztedI8 is an unknown quantity at this point
Exclamation weird headlight and lock problem
I have a 98 blazer. it just started this weird thing with the locks and headlights. First the locks just lock themselves and when they do that the headlights come on. i checked the switches and it is still doing it. i will be watching tv in the house and all of a sudden the headlights just come on or drls depending on the time of day, and the keys will be in my pocket. i have asked everyone i know and just cant figure it out. on top of that my keyless remote will unlock the doors but not lock them. any suggestions will help.. thank you
Old Apr 1, 2010 | 03:30 PM
Sounds like something is amiss with the RKE module.
Old Apr 1, 2010 | 03:35 PM
twiztedI8's Avatar
im sorry. i know enough to get me by. what is the rke module and will i be able to tell if somethin is wrong with it?
Old Apr 1, 2010 | 03:41 PM
RKE = remote keyless entry
Since you are having problems with your locks randomly locking and kicking on the lights, I'd say that is confirmation that there is a problem...
Old Apr 1, 2010 | 03:44 PM
twiztedI8's Avatar
is there anything i can do about it or do i need to take in to a shop? it does it randomly. Maybe a way to disable it untill i can get it to a shop? thanks for the info so far. it makes sense
Old Apr 1, 2010 | 11:00 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Remove the lower hush panel on the drivers side. It's the plastic panel above your feet. The RKE module is attached to the inside of it. Unplug the plug and reassemble.
Old Apr 2, 2010 | 01:32 PM
twiztedI8's Avatar
Default unhooked RKE and still have the problem.
thanks for the info. i tried unplugging it and i still have the same problem as mentioned above. i have no idea what is going on with it. i might just have to break down and take it to a shop and take the hit. another thing i found is that the locks will lock by themselves and its like if you were to hold the lock switch down. when the blazer is started the locks wont even work. if you hold the lock side of the switch down, the headlights come on. as well as it doing it by itself. i would tear into it but i am not that good on electrical. if it comes to turning a wrench then i can do it...lol. well if anyone has any other suggestions or this problem has happened to you, i would appreciate some imput. also i dont know if this helps but when i turn the key to start it the doors lock. this never happened before. thanks
Old Apr 4, 2010 | 02:58 PM
twiztedI8's Avatar
someone told me that i might have a problem with the BCM. i dont know if thats true. but if it is can i do that myself or do i have to take it to a shop? thanx
Old Apr 5, 2010 | 07:41 AM
You could swap it out with a known good one that as the RKE option, also. If you do, you need the airbag module from the donor truck or your airbags won't work. You've also got to do a 30 minute passlock relearn procedure.
domorovich
Feb 5, 2012 02:45 PM
hotrodsbyg
Aug 15, 2011 11:47 AM
lunchbox79
Apr 29, 2010 12:17 PM
gERgMan
Sep 6, 2008 07:27 PM
Kein_mitleid
Apr 9, 2006 04:06 PM
