Just a update from that mfi injector update repair on my 98-
Houston- we have a problem. Not good, that’s not good. Guilty location fixed.
So yea started noticing coolant on driveway. Brought into garage and yep, leaking but only when under pressure. Hard to find when hot so son’s pal had a tool to pressurize and test. Whole lot easier, found leak. Was clamp on recirculate line behind alternator down low. Thank gosh not the LIM gasket from that injector job, no way want to do that job anytime soon again. Pulled, moved a bit and relocated clamp a bit higher up on tube and tightened, tested under pressure 16lbs for 1 hour, no problem. Yippee. Figured I’d update you all on how it has been doing since that repair. Other than this which I just fix yesterday everything else A-ok. Running like a top. Still need to sort out rear wiper but nothing I can’t handle. Hope your all well- Tig
