what should my idle be ??
Old 09-15-2005 | 06:45 PM
yzf125's Avatar
yzf125 is an unknown quantity at this point
Default what should my idle be ??
Hey guys, I have a 2002 blazer with a 4.3 and i was wondering what my idle should be at park and then in drive, thanks
Old 09-16-2005 | 06:17 AM
Joshua M. Smith's Avatar
Joshua M. Smith is an unknown quantity at this point
Default RE: what should my idle be ??
850 +/- 50rpm depending on conditions (is the truck warm? how warm? etc.).
Set by screwing curb idle bolt out, then back in until the IAC takes over. Do this with a warm motor.
Do not use the curb idle adjustment to set the idle.
Josh <><
Old 09-16-2005 | 09:19 AM
yzf125's Avatar
Is that 850 in park ? When i put it in drive it is around 500 , and the motor seems to run a little bit rough, Is that to low ? Thanks.
Old 09-16-2005 | 07:20 PM
Hello,
That sounds a bit low. Pull the IAC and make sure it's not gummed up. Do NOT try to move the pintle (pointed thing) as it will ruin the part.
Take some carb cleaner and clean it (excepting any rubber parts) and clean out the hole it fits into.
You might also check to see if your EGR valve is functioning properly.
Josh <><
trobbins
01-09-2013 10:17 AM
ncpatsfan
07-15-2012 05:05 AM
Chevrolet.Love
08-19-2011 09:05 PM
97BLAZE4X4
02-07-2010 07:33 PM
billthegoat
10-06-2006 09:15 AM
Quick Reply: what should my idle be ??
